Aftermarket Stereo Installation
Posted: Tue May 19, 2020 8:45 pm
Covers:
1989-1992 2.2L 4-Cylinder Engine
1989-1992 2.2L 4-Cylinder Turbo Engine
1990-1992 3.0L V-6 Engine
Required:
Phillips Screwdriver
DIN Removal Tool (or two pieces of coat hanger wire)
Wire cutters
Wire stripper/crimper
Electrical tape, wire connectors or soldering iron, wire shrink tubing
Metra 99-5556 Single Din Stereo Installation Kit 1988-1992 Ford Probe
Metra 70-1770 connector wiring kit.
Procedure:
Step 1: Removing The Factory Stereo Unit
Step 2: Installing The New Stereo Unit
Extra:
Aftermarket Stereo Unit Wire Colors
Factory Speaker Dimensions
Remove shifter trim:
Automatic Transaxle: Remove the trim piece around the shift lever by prying upwards.
Manual Transaxle: Slide shift boot down and unscrew the shift knob. Remove the shift boot then remove the trim piece around the shifter by prying upwards.
Remove ash tray. Remove the ash tray trim by prying up on the front of the trim piece to detach the clips.
Remove the two mounting screws at the bottom of the stereo assembly that were behind the ash tray trim.
Insert the the DIN removal tools into the holes on the edges of the stereo unit face. If you don't have the DIN removal tools, get two 8" pieces of coat hanger wire and bend them each into 'U's to use in place of the DIN removal tools. There should be two holes on each side in the face of the stereo unit. Place the tips of one tool into the two holes on the right side. Slowly slide the tool into the unit until a light click is heard or felt. Repeat for the left side. Push the outer ends of the tools outwards away from each other. This should release the metal springs holding the unit in place. Pull the unit out from the console. This should be relatively easy... if not, the clips are not being released properly. Do not force the unit out.
Remove the unit and detach the antenna wire, and two connectors from the rear of the stereo unit.
Install this kit Metra 99-5556 Single Din Stereo Installation Kit 1988-1992 Ford Probe
If your Probe came with just an AM/FM radio or AM/FM Cassette unit, mount the radio using the hardware that came with the new unit. Some creativity may be required. If your Probe came with a CD player, you will either have to obtain the OEM tray that normally is under the radio unit of Probes without CD players, or use the metra kit which blocks the opening.
Connect the wiring as shown below to the Metra 70-1770 and plug it in.
stereo_1_w08 (1).jpg (22.48 KiB) Viewed 900092 times
If your Probe has the premium sound system option and you plan to use the factory amplifier with your new stereo unit, proceed with amplifier instructions in this forum.
Connect the antenna wire to the stereo unit.
After all connections are completed and the new stereo unit is mounted, reinstall ashtray, ash tray trim, and shift trim.
If your Probe had the premium sound system option and you do not plan to use the factory amplifier with your new stereo unit, you must bypass the amplifier completely. For instructions, continue to Factory amplifier bypass instructions in this forum.
More information for the diy
356005.pdf
(640.46 KiB) Downloaded 176 times
