Technical Service Bulletins: 99-24-09
Posted: Tue Jan 28, 2020 11:25 pm
  • Leak - Automatic Transmission Fluid - CD4E Transaxle - Fluid Seeping From Vent, Resulting In Fluid Collecting On Main Control Assembly
    Leak - Automatic Transmission Fluid - CD4E Transaxle - From Transaxle Fluid Fill Tube
    Transaxle - CD4E - Transmission Fluid Leaking From Transaxle Fluid Fill Tube
    Transaxle - CD4E - Transmission Fluid Seeping From Vent, Resulting In Fluid Collecting On Main Control Cover
PUBLICATION DATE: November 22, 1999
FORD
1994-97 Probe
This TSB article is being republished in its entirety to update the model year coverage, add a concern to the title, and revise the Service Procedure.
ISSUE Automatic transmission fluid may be seeping from the grommet-style vent assembly and down the main control cover or may be leaking fluid from the fluid fill tube on some vehicles. The appearance of fluid on the main control cover may be misdiagnosed as a leak in the cooler line and/or main control cover gasket.
ACTION Diagnose leak and repair by referring to the following Service Procedure for details.
NOTE: BEGINNING JANUARY 1997, ALL CD4E TRANSAXLES CONTAIN A REVISED MAIN CONTROL COVER (F7RZ-7G004-AA), FIGURE 1, AND VENT TUBE ASSEMBLY (F7RZ-7034-CA FOR PROBE AND F7RZ-7034-BA FOR CONTOUR/MYSTIQUE), FIGURE 2. THIS NEW DESIGN WILL PREVENT FLUID FROM SEEPING FROM THE VENT. IF THE VENT HOSE IS KINKED OR BLOCKED INTERNALLY, FLUID WILL LEAK FROM THE TRANSAXLE FILL TUBE.
For 1995-1997 Contour/Mystique Vehicles Built With Grommet-Style Vent Assembly Main Control Cover:
NOTE: BEFORE INSTALLING NEW VENT TUBE, PURGE ANY OBSTRUCTION FROM THE HOSE LINE USING LOW PRESSURE AIR SUPPLY. HIGH PRESSURE CAN BLOW PAST ANY OBSTRUCTION WITHOUT EVACUATING THE HOSE. WHEN INSTALLING THE HOSE, FOLLOW THE INSTRUCTION SHEET PROCEDURE WITH THE VENT TUBE KIT, ENSURING THE HOSE IS NOT KINKED.
If fluid is detected on the main control cover near the vent and the area around the grommet is damp, check the transmission fluid level. If the fluid level is below the crosshatched area, check for alternate leaks. If the fluid level is between the crosshatched area, service with Remote Vent Kit (F6RZ-7034-AA).
If replacement of a main control cover is required, replace with a new Main Control Cover (F7RZ-7G004-AA) and a Vent Tube Assembly (F7RZ-7034-BA).
For 1994-1997 Probe Vehicles:
Transaxles built with grommet-style vent assembly main control cover CANNOT be serviced with the new main control cover. If cover replacement is required, service with the grommet-style vent assembly Main Control Cover (F4RZ-7G004-A).
If repairing a vent seeping problem on the grommet-style vent assembly main control cover, use the Remote Vent Kit (F6RZ-7034-BA).
For 1997 Probe, 1998-2000 Contour/Mystique, And 1999-2000 Cougar Vehicles:
Vehicles built with the new designed main control cover must use the new Main Control Cover (F7RZ-7G004-AA) and/or new design Vent Tube Assembly (F7RZ-7034-CA for Probe, F7RZ-7034-BA for Contour/Mystique) if replacement is required.
NOTE: FOR PROBE APPLICATIONS ONLY, THE NEW DESIGN MAIN CONTROL COVER AND NEW DESIGN TUBE ASSEMBLY CANNOT BE INSTALLED ON PREVIOUS MODEL VEHICLES DUE TO A REVISED AIR CLEANER DESIGN.
Service Procedure
NOTE: USE THIS SERVICE PROCEDURE IF REPLACEMENT OF THE NEW DESIGN MAIN CONTROL COVER AND/OR NEW DESIGN TUBE ASSEMBLY IS REQUIRED.
PROBE
Fully seat straight end of tube onto brazed fitting on main control cover. Mount clamp securely onto brazed fitting to secure tube assembly (Figure 3).
Route tube assembly toward rear of vehicle.
NOTE: BE SURE 90 DEGREE ELBOW IS FACING DOWNWARD.
Install tube assembly on air cleaner housing and align white dot with retaining bracket closest to front of vehicle. Insert 90 degree elbow end of tube assembly into air cleaner clamp. Allow approximately 25mm (1") of free tube (Figure 4).
CONTOUR/MYSTIQUE, COUGAR
Route tube assembly upward toward the rear of the battery (Figure 5).
Attach clip to battery hold-down bracket bolt (Figure 6).
Be sure 90 degree tube end is routed downward (Figure 7).
NOTE: USE SERVICE KITS FOR PREVIOUS DESIGN GROMMET-STYLE VENT ASSEMBLY MAIN CONTROL COVER.
The 1994-1997 2.0L CD4E Probe Remote Vent Kit (F6RZ-7034-BA) consists of the following parts:
One (1) Vent Tube - 460mm (18.1")
One (1) Barbed Vent Body
One (1) Clamp
One (1) White Plastic Clip
One (1) Black Steel Clip
One (1) Instruction Sheet (I.S. 7142A)
The 1995-1997 Contour/Mystique Remote Vent Kit (F6RZ-7034-AA) consists of the following parts:
One (1) Vent Tube - 640mm (25.2")
One (1) Clamp
One (1) Instruction Sheet (I.S. 7143A)
  • F6RZ-7034-BA Remote Vent Kit (Probe)
    F6RZ-7034-AA Remote Vent Kit (Contour/Mystique)
    F7RZ-7G004-AA Main Control Cover
    F4RZ-7G004-A Main Control Cover (Probe)
    F7RZ-7034-BA Vent Tube Assembly (Contour/Mystique)
    F7RZ-7034-CA Vent Tube Assembly (Probe)
OTHER APPLICABLE ARTICLES: None
SUPERSEDES: 97-5-9
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
LABOR ALLOWANCE
OPERATION DESCRIPTION TIME
  • 992409AB Additional Time To Replace Main Control Cover, If Required - 1995-1997 Contour/Mystique 1.0 Hr.
    992409AC Additional Time For Vehicles Equipped With A/C - To Be Used Only With Operation AB - 1995-1997 Contour/Mystique 0.2 Hr.
    992409A Install Vent Tube Kit - 1995-1997 Contour/Mystique 0.5 Hr.
    992409BB Additional Time To Replace Main Control Cover, If Required - 1994-1996 Probe 1.2 Hrs.
    992409B Install Vent Tube Kit - 1994-1996 Probe 0.4 Hr.
    992409CB Additional Time To Replace Main Control Cover, If Required - 1997 Probe 1.2 Hrs.
    992409C Install Vent Tube Kit - 1997 Probe 0.3 Hr.
    992409DB Additional Time To Replace Main Control Cover, If Required - 1998-2000 Contour/Mystique 1.0 Hr.
    992409DC Additional Time For Vehicles Equipped With A/C - To Be Used Only With Operation DB - 1998-2000 Contour/Mystique 0.1 Hr.
    992409D Install Vent Tube Kit - 1998-2000 Contour/Mystique 0.4 Hr.
    992409EB Additional Time To Replace Main Control Cover, If Required - 1999-2000 Cougar 1.9 Hrs.
    992409EC Additional Time For Vehicles Equipped With A/C - To Be Used Only With Operation EB - 1999-2000 Cougar 0.1 Hr.
    992409E Install Vent Tube - 1999 Cougar 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
7034 42
OASIS CODES: 501000, 502000, 503000, 504000, 510000
